Georgia Popcorn wrote:
tyoungs wrote:
purchaser is the one who noticed the error message, they gave me a deposit knowing this was an issue - just "trying" to see if I can find an easy fix and correct this. They have an extended warranty that comes with purchase so are not particularly concerned. No nefarious intent here, just looking to help out if I can get some idea as to what the issue is
I had the "error code-external" show up when we were in Ft Myers.
What I learned:
The leveler has sensors attached to the underside of the floor in the MH, normally in the forward storage compartment, right side and also in the Aft storage compartment left side, they read each other thru radio (you will note a small antenna hanging down from each one...What I discovered, the connection at the sensor is joined together with a plug at the sensor, when we unplugged the connection, it was evident that one of the wires was not pushed all the way into the connector (white, probably ground). I pushed the wire into the connector with needle nose pliers, and all was working good, and has ever since.
You may need to "learn " again.
1. This thread is about LCI HYD jacks on a motorhome.
2. Your sig shows a 5th wheel. Which should indicate you have the Electric GROUND CONTROL LCI system. Please confirm if this is right
3. The reason is, IF you have Ground Control, there is NO RF sensors at all. LCI Ground Control, is ALL hardwired.
4. Please state the Brand and Model of your level system. Doug
