NaViDa's avatar
NaViDa
Leak around base of Toilet.
Hi,
I recently purchased my first RV, which i'm happily living in it fulltime for about 3 weeks now. Its a 1998 Holiday Rambler Endeavor. Yesterday i notice some of the blue sanitizer leaking around the base of the toilet and last night what seem to be urine. As a female that loves DIY, will i be able to tackle this alone without taking it into a RV dealership??
TIA!
  • newman fulltimer wrote:
    Is your black tank full seeing you are seeing blue treatmant
    Thanks everyone for your speedy recommendations!!
    I'd read thats its good idea to empty the black tank bi-weekly, so this could be the problem since my levels seem to stay at 2/3 full after i've emptied it or not??
    I do have the type toilet mentioned here with the foot lever, something i really enjoy using!
    I'll check everything stated here starting with emptying the black tank today.
    THANKS AGAIN!
  • If you have a Thetford toilet you might want to consider buying the water water valve kit, which includes the base gasket. My water valve started leaking a couple months back and the coach is only 6 years old.
    The whole kit runs about 20 - 40 bucks, depending on the model of your toilet. You need to remove the toilet to change the water valve so now would be a good time.
    The whole project took me a little over a half hour and minimal tools.
  • Fairly easy fix. Just changed my base to flange and the bowl to base gaskets out last month on my 2000 HR Endeavor. I was having odor issues and found both seals were leaking. New flange seal is about 1/2 inch thick and the old one was about as flat as a quarter. Mine had the carpet on the base and you could tell it had also leaked blue water at some time.
    You just need to disconnect the water supply line, remove the trim from around the base of the toilet, if you have the foot flush you will need remove the trim from it as well, then remove the 4 nuts holding the toilet down. You should now be ready to lift up and remove the toilet.
    The gasket will either be on the toilet or stuck to the flange. My gasket came with 4 new bolts and nuts, also easy to replace. Clean everything up, align the new gasket and re-install.
    The gasket shown in the other post goes between the base and the toilet bowl. Mine was leaking there as well so I replaced both. For that one you will need to remove the large hose clamp that holds the base and bowl together. All of this is also easy to do if you remove the toilet from the motorhome, remove the lid and turn it upside down.
    You will also need some rubber gloves.......
    While mine was out, I ripped out the carpet, built a new base and went back with ceramic tile. Hated that carpet around the toilet.
    Good luck and send me message if you have any questions.
    Michael
  • joelc's avatar
    joelc
    Explorer III
    Ivylog wrote:
    Yes this is something you can do. Click on this link and the second picture is the instructions on how to change the $20 seal.
    X2 :R
  • Ivylog's avatar
    Ivylog
    Explorer III
