We took our rig out for the New Year's weekend and experienced rain all three days out here in beautiful sun shiny Arizona. During our time, we noticed water coming in at the lower left hand corner o...
If your seals are not good, then yes you would benefits from having new installed, or do it yourself. What we have found is that sometimes the seals on the side do not pull out all the way like they should when the slide is extended. We use our awning hook to slide the outside edge of the seals out like they belong. We have also discovered that if we are not level, the slides leak. If we are level, they stay dry.
