2gypsies wrote:
We found that by the time you slowed way down entering a campground and then drove to your spot and parked, that was sufficient time for shutting down.
The same goes for when you leave, have everything stored THEN start it up, pull in the slides and by the time you get to the highway you're good to go.
EXACTLY the same concept as on start-up. Common sense is needed.
As you say, if in a CG and you are going to drive out of the CG and a mile or so at low speeds "you are free to move about the country" as soon as air pressure is built.
After spending the night at a Flying J at the entrance ramp to the freeway, then idle (high idle-- like 1000 RPM please) until engine coolant temperature is 150 degrees F or so.
There is a reason that there is something on top of our NECKS.
