Cloud Dancer wrote:
Does it hurt anything to always let the turbo(ed) engine run at idle for 5 minutes before shut down?
Yes. Environment. (not to mention owner pocket)
In California they actually made a law forbidding idling.
Wolfe is making good point about thinking.
I was hauling heavy with my manual diesel pickup in the past, but when I was coming to rest area, I would switch to N about 1/2 mile before exit. By the time I rolled down to stop the engine already had couple of minutes of low rpm with good air flow.
Not all turbos require cooling.
We drive turbodiesels in Mercedes for over 20 years and cooling them down was never an issue.
You can also buy a module that will keep engine running for few minutes after removing key from ignition.
My son bought gasoline, sport car Mitsubishi where PO installed such module to prolong turbo on it. Sure made some strange looks when you close the door and walk away from car with engine running.
Than some engines do have electric coolant circulation pump that will even engine hot spots for few minutes after shut down.
