FLHTCI's avatar
FLHTCI
Leaving tomorrow 13 degrees.
I’m leaving Massachusetts tomorrow for our inaugural trip in our Winnebago Itasca, Sunstar 30T. I was told that filling the freshwater tank is okay if the heat is on to at least 55 degrees. Now that I’ve done this I fear I’ve made a mistake.
Please advise, should I flush the whole system?
Thank you
  • We have relatives in Massachusetts and they are predicted to get to 10 degrees Fahrenheit tonight. I would run an small electric heater on low or medium in my sewer drain pipe area. I would open all cabinets and sink and shower doors as well as leaving the thermostat set on 45 or so. Run the water heater to temp if you have water in your fresh water tank.
  • As long as you keep the belly warm and keep some heat going inside as well (open all the cabinets where any water lines might be located) then you will be fine. It doesn't need to be 65, but around 40 is pretty safe. The water tank itself is unlikely to have issues as the warmth of the water will help keep temps more stable in the belly area. IF, IF, you have NO exposed sewer drain pipes or these pipes have no fluid in them then they are OK at any temperature but once you flush you will have to keep all drain pipes exposed to those kinds of temps warm as well. Once you get away from the 17's and into the 35's then you are good to go for most anything you like.
