Executive45
Sep 22, 2014Explorer III
LED Mod wih pics
So, it was raining today. I decided to fix one of my overhead florescent fixtures. The ballast had failed and I didn't want to spend the $$ for a new fixture. I purchased a roll of LED's and ends from Amazon for $19.90 including shipping. The roll of LEDs is 16.4 feet long and I used two strips, each 16" long, so I have tons left over. The ends came 10 to a pack so I have 9 left. Here's some pics:
BEFORE
AFTER
BEFORE
AFTER
The install was easy. Remove the plastic cover and the florescent tubes. Turn off power. Remove ballast cover by squeezing and pulling down. Snip the black and white wires and save. Snip all other wires and tube ends and discard. Using the ballast cover allows you to assemble the lights on your workbench. (I originally was going to use four strips but two is more than sufficient.) Measure the length of the LED strip and cut on the mark. Peel the backing off the LED strip and install. (I used double sided tape, cut lengthwise for extra holding power) For the second strip, use one of the 10 connectors. Attach both the red wires from the LED strips to the black wire from the fixture. Attach both the black wires from the LED strips to the white wire from the fixture. Reassemble and turn it on....DONE!
Here's the parts list:
10 Piece LED Strip Connectors
LED strip lights
BEFORE
AFTER
BEFORE
AFTER
LED strip lights
