moisheh's avatar
moisheh
LED TV Mount
I am in the process of mounting a modern TV in our 05 Bounder. Most of the non articulating wall mounts just hang the TV on a bracket. What do you use to keep the TV from bouncing off the bracket? My TV is a 32 inch Vizio and is just over 10 lbs. I was going to mount the TV in the old front TV box on a permanently installed 3/4 inch plywood that goes from side to side. Now I have decided that in order to access the area behind the TV for adding a cable or removing the TV it is better to have the plywood on hinges. I haven't decided whether to use a piano hinge or maybe 2 of the 3.5 inch residential door hinges. Any help appreciated.
Moisheh
  • I mounted the plywood solid put a big hole in it to access all the cables and plug in back.mounted tv to a removable mount and used small angel brackets 1 on each corners good and solid and can be removed easly.
  • Check with Fleetwood for a bracket. We mounted a LED in our Itasca and Winnebago makes a bracket for RV's. The TV is real solid, it's not bouncing off.
  • The bracket should have a locking pin on it to lock the two together. never seen one that doesn't.
