J-Rooster wrote:
RayChez wrote:
coolcity, You are suppose to level first, then you put the slides out. Common sense will tell you that. If you have any mechanical know how, you will know right away that you set up your platform first, then you can put the slides out without putting any twist on the frame of the coach.
X-2, Ray is correct level first with jacks down!
Not with a Roadmaster chassis.......slides out, dump air, then level. You reverse the procedures when leaving. If you do not follow that procedure, you will eventually crack a windshield and bind a slide.
