campingman55 wrote:
ok we just got our new  old dp it is a winnabago vectra 40fd and it is a2005   we would like to know do u bring the slides in with the jacks down and do u run the slides out with the jacks up need to know what way is the best
I don't know if you have the Operator's Manual for your coach. If not, you can find it here:
2005 Vectra Operator's ManualThe manual states that you level the coach before moving the slideout. All Winnebago products I've looked at state the same thing. Other brands of coaches are different.
When I'm working on my coach here at the house, I often run one or both slideouts out, without extending the jacks first. My driveway is pretty much level front-to-back, and has a slight slope away from the house. Slides work fine in this situation.
You will see in the Op Manual that Winnebago recommends using the jacks to raise the side of the coach opposite the slide, to force water runoff if there is water on the slides, before retracting the slides. That implies to me that Winnebago doesn't consider it a great sin to move the jacks while the slides are out.
This post provided for information only.
