Tragikmagik72's avatar
Jul 08, 2020
Leveling Jack issue
Hey everyone!
I’ve searched around on here before making a post but couldn’t find exactly what I’m looking for.
I have a 2004 Newmar Class A, and I’m having an issue with one of my hydraulic leveling jacks not retracting properly. It had always been slow to retract compared to the others, but this year will not retract at all. The last time I used it, I had to loosen a solenoid/valve to relieve the hydraulic pressure and it came up just fine. This one solenoid was also very hot compared to the others too. So that’s leading me to believe that maybe it is bad and causing my issue?
It’s an HWH Corporation system. And I’ve tried looking it up but nothing I could find shows the valve or solenoid or whatever it actually is, or any part numbers for that piece so that I could order or look for a replacement. So here I am, hoping maybe someone has some insight or advice.
I’ll post a pic of the part I’m talking about. It looks like one has been replaced before. But there are no makings to help identify what I actually need to look for. Any help or advice would be greatly appreciated.
As I type this I’m realizing that maybe I should swap two of these up and see if this piece causes a similar problem on a different jack..
Link to image https://ibb.co/pbbyZBY
  • What model HWH? If you swap two you will need to get O-rings for both as they should be replaced it you remove the valve.
