AikenRacer's avatar
AikenRacer
Leveling jack replacement on 2011 Damon
We have a 2011 Damon gas motorhome. Replacing the front leveling jack. I have a couple of questions.
1) Once the new jack is on and connected, do the lines have to be bled and if so, how do you do it?
2) The reservoir for the hydraulic fluid has a screw fill cap with a dip stick connected to it. No markings on the dip stick except for two lines. No markings on the plastic tank either. I presume one is full and the lower one is add. Question is should the level be checked with the jacks down or up?
3) Any other tips or comments welcome.
Thanks!!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Power gear hydraulic jacks say to run the jack all the way down. then retract it THREE TIMES using the controls inside.
    I would suggest running the front end of the coach up on at least 3 layers of 2x tire width plank
    Since my jacks are non-op I have a set of stair steps not unlike the ones in the current edition of FMCA mag.. But slightly different.
    They beveled the lead end of the planks (I did not 22.5 inch wheels you don't need tobervel)
    one plank 3 foot
    one two foot
    Oen one foot
    I you are not careful you can over run so a "Stop" say just beyond that last step might not be a bad idea (add 4 inches to each layer and put a beveled 4x4 on the end of the top step)
    or in your case you can lay plank down and not glue 'em together as I did.
    Then run the jacks down 3 or 4 times to maximum extention and retract.. That's what Power gear says will do it.. Me. not so sure. When I re-activate mine I'll install bleeders.
  • Level is taken with jacks RETRACTED. Odds are you have LCI jacks or Equalizer. BOTH, level is done Retracted. IF LCI or Equalizer. Operate the jacks to full extension and retraction 5 times. Leaving the jacks fully extended for 10 minutes between operations. This allows the air in the system to migrate back towards the reservoir. If HWH, they are self bleeding. Just extend and retract 2 or 3 times. Doug
