Executive wrote:
If you're looking for a rather permanent fix without the expensive hydraulic jacks, I would have four scissor jacks welded or bolted to the coach frame. Use caution if welding and follow your coach's directions and cautions. Depending on your budget, these can be powered or manual. If you opt for manual, you could use a battery operated drill to power them down. If you have them installed under the front and rear bumpers, they would not be too obtrusive and access would be pretty good...good luck...Dennis
I'm leaning towards the powered scissor jacks that have a 5k load rating, that should be enough. My coach sits pretty low to the ground, partially due to, I believe the springs are tired, but the airbags will raise it 2-3" if I remember correctly, but I think they will fit up in there without hanging too low.
