I stopped using the auto level feature. It seems like it would make it way more complicated than it needed to be. Like a Rube Goldberg machine. Twisting and creaking the MH, back and forth, up and down and eventually level but in a way that made no sense often with one or more of the wheels off the ground. Almost like it was continually compensating for itself. I manually level and it's so much easier and simple and I can do it in 1/4 the time. I have level bubbles in the MH but more often than not, a lot of MH surfaces aren't parallel. Like the countertop and the table and the floor are all just a tad bit off. I use the level on my smart phone in various spots and take the median. We also have a large slide and I tend to favor that side a hair higher as I know after a day or so that side will settle down an inch or so because of the weight. I don't stress over it, it's a MH usually on a non level surface with tires and suspension that will settle and move a bit, so I get it as close as I can and move on to other things.
