GHOST1750's avatar
GHOST1750
Leveling question.
Has anyone else found that when you push the auto level button it sometimes does not completely level and if so do you level manually? I Carry a level with me as I did in my older motor homes. Still getting used to all the new fangled things on this motor home. It is a 2013 Newmar Canyon Star. Still trying to get used to going from diesel to gas.
  • If anyone is moving around in the motorhome when it is auto leveling, it will never level correctly. Doug
  • Get the manual and go through the recalibration procedure. Find a level parking lot to do it in. Some just never seem to get things perfectly level, though..... Maybe you'll be lucky and have one that does...
  • I have an 05 Fleetwood DP with Powergear auto leveler. If the left side is low, it levels almost perfectly but the left side will still be just a tad low.
    If the right side is low, then when finished, the right side will be a tad low.
    I’ve recalibrated it but it’s the same. Never really bothered me. If the ac was dripping by the door I would set it to manual and bump it a little to compensate.
