Broke one of the leveling springs yesterday on my dp. I found part number already and a lot of places to buy them. How hard is it to change them? Is it easy to do and is there any tricks to do it?
You stretch the spring and put the washers in. That makes the spring longer. Simply hook each end in appropriate hole and extend the leveler and the washers fall out. Just make sure washers are big so they fon'T fall down inside spring. NO need for bottle jack. I'be done mine several times.
The hardest part for me is getting up off the ground!!!
