x5 to the tri levelers. They are so much easier than the blocks and sturdier too. We have smushed several of the yellow blocks but the tri-levelers keep on keeping on. We use 2 tris and a set of 10 yellows. Boondocking it could take us up to an hour to get level--or find a spot level enough to get level. Really! And I'm talking half a bubble in the fridge not perfectly level. Mostly in campgrounds a couple of tri's will do you and at less expense than the blocks. They don't have to be the same height on each side. We often place one right under the tires and one a bit further up to level. We do support both back tires though so guess a set of blocks or a couple more levelers would be needed.
