Just realized I left out a detail. The horse mat is 3/4" thick, so you need to stack them to get a lot of height. Since the Lynx blocks are 10" wide, I used that measurement when thinking about stacking. If everything is aligned to the front, you can safely stack up to a 4.5" total rise. If you need more than that, then you should find a better spot. I will try to make a simple graphic showing how I use the mats.
= (stacked 10 " pieces)
== == (stacked 16" pieces end-to-end)
= == == (stacked 10" pieces, stacked 16" pieces end-to-end)
The arrangement above makes for a very easy drive onto the staggered pads. Although I have stacked 3 high and just muscled on.
Jose
