road_glide's avatar
road_glide
lighted? 120 volt red water heater switch
The 2 red rectangular rocker switches on the inside control panel for the water heater are red in our coach and our last coach Holiday Rambler 2002. Is the electric 120 volt rocker switch in red next to the propane rocker suppose to light up when on? don't think it did on H/R, but can't remember...
Propane switch lights up as well as the little red dot showing ignition.
Reason I'm asking is house battery switch by door the red light next to it is out and found info on it to replace..nothing yet on water heater
    Both my switches used to light up, but the bulbs burned out and I've never replaced them. I really do need to replace them because you don't want to forget and leave them on while the motorhome is in storage. You could use up all your propane heating water for nothing.
  • korbe wrote:
    The red light in between our two switches only comes on when the propane did not light - after the 3 tries.
    Propane switch is okay just wondering about the other (electric) red switch light...
    so far I found sigma T-55...still researching...thanks
  • The red light in between our two switches only comes on when the propane did not light - after the 3 tries.
