daved9664's avatar
daved9664
Liquid Roof! Whats the worst youve seen it fix?
Hello everyone.
Im going to put liquid epdm on my tpo roof using the primer product they offer.
My question is whats the worst roof youve seen come back after a liquid roof coating?
Most of the roof is intact, with good rubber. Though there is one area where it peeled off exposing the wood underneath. Will a calk / eternabound application solve this in combo with the liquid roof?
Some folks I talk to say to replace the wood and everything. That's going to cost a lot more. If calking, taping, then recoating works, I'd like to do that. Just wondering what any of you have experienced
  • I used EPDM Liquid Roof on our Bounder. While it did seal the roof as it is suppose to, in a matter of months it developed gray splotches all over and looked as bad as it did before I coated. EPDM was no help at all in resolving the problem. Chuck
  • I'm in the process of using this to repair a slide out roof on a 97 Bounder
    https://www.amazon.com/gp/product/B01NAPJ42A/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    Superior RV is a one part coating, based on new styrenic, thermoplastic, block copolymer technology. The product requires no catalyst, primer or tape, and provides total RV roof restoration for tpo, epdm, fiberglass, plywood, vinyl and aluminum. This can will complete 42 square feet of roof (including two coats). FEATURES • The Strongest RV Roof Coating Anywhere!! • 800% Elongation • 1900 psi Tensile Strength • One Part - No Catalyst, No Mixing • No Primer or Tape Required • Withstands Ponding Water, Snow, Ice, Hail, and Intense Sunlight • Prevents Leaks & Premature Aging • Incredible Adhesion to TPO, EPDM, Aluminum & Fiberglass • Resists Hail Impact & Dirt Pick-up • Bright White, Heat Reflective Finish (90% reflective) • Remains Flexible Below -70ºF • Rain will not harm uncured product • Instant Waterproofing • 15 Year Guarantee • Includes 2 Rollers Finally….a one part roof coating that does it all!
    Well see how it holds up
