John___Angela's avatar
Feb 26, 2015
Location of ECM on an ISC350
Hi Folks. Some may recall I had a check engine light in the fall that I traced to a bad ground. While looking for this I had suggestions from some on also checking the ECU. The thing is I never actually found the ECM and I would like to know for future reference as I think the problem may still be intermittent. I wonder if someone could chime in on where it is and more specifically if you could give me a reference when looking straight down on the motor facing the back of the coach. It is a 2003 ISC-350 Caps motor.
Thanks in advance.
J and A
  • In the Mororhome application where the ISC is mounted facing the rear. it will be on the passengers side at mid engine under the engine fuel filter. it is a aluminum box about 1.5" thick and 6"X8" square, mounted by 3 1/2" bolts. and has one huge multi pin connector plugged into it.
  • It is attached to the drivers side of the engine block.
    (I know, the last place you, or at least I, would ever look :B)
