dougrainer
May 09, 2015Nomad
To the OP, WHY do you think your HWH reservoir is low?? UNLESS you have a leak(that would be visible), there should be no reason the reservoir would be low. The HWH tank holds 5 to 7 qts depending on the system and at any time only about 2 to 3 qts is used when all hydraulic functions are used, leaving 2 to 3 qts left. Doug
