FIRE_UP
May 09, 2015Explorer
cbeierl wrote:FIRE UP wrote:
Now, if you feel that, that reservoir is low, make sure all the Jacks are completely up and, all the slides are completely retracted. Then, and only then, you can remove the reservoir cap and check the fluid level. Hope this helps.
Scott
Note that there is a least one type of HWH slide mechanism that requires the slide to be out when checking fluid levels. On my 36RD the bedroom passenger-side slide needs to out and all of the others in.
Well Chris,
As usual, learn something every day. Now, what was it that learned from yesterday, and the day before that and.....
Scott
