lspencer's avatar
lspencer
location of valves on hwh kickdown jacks
hello everyone. I have a 2000 Damon Challenger 330. it has the hwh joystick 210 series leveling system on it. my left rear jack will not retract. it kicks back up when the rest of them do but it will not retract. I have looked in the owners manual and it said to open the valve for it and then pry up the cylinder. I have looked everywhere under the coach and can't seem to find the valve. I think I found the hydraulic fluid reservoir under the coach dead center of the frame but I can't find the valves. the manual also said that the valves are easy to access. has anyone else had this issue and can tell me where the valves and reservoir are located. any help would be great.
  • I had hwh kick down jacks on an earlier mh, on mine the everything was mounted together , valves, reservoir , and pump, were all in one location. Up front take a closer look at what you found
