- Big_KatunaExplorer IISo Trimark sells cam locks that use the same keys as your storage bays..
You should have key codes on your OEM keys. - Big_KatunaExplorer IIMany DPs have this feature. We don't have a keypad but do have a FOB.
We don't use it as it randomly u programs itself so we had to carry a key anyway.
I don't carry all my keys once I'm set up. I have one door key on my every day key ring.
I have a ring with the outside keys hanging by the door when I need them. - MagillaGorillaExplorerWouldn't it be great if we had keyless entry or even a code lock for the camper door? Something like what Ford has on their cars. Punch in 5 numbers and it unlocks. No need to carry keys when you are camping.
- BillinwoodlandExplorer
JimM68 wrote:
Mine, those lock cylinders are all different...
Ignition key looks like a '60's GM.
The basement doors have a "double-sided key"
The fuel doors have something that looks like it's from a cheap padlock.
The entry door deadbolt is completely different. The main entry lock I never use because we have remotes for that, think it is different too.
Then we have the round ones to get into where the a/c condenser, trans cooler, and powergear motor are...
I think Monaco just liked locks.
And to make it worse, those double sided keys, at least mine, can not be made at a local hardware store. I have to take mine to a locksmith as Ace, True value, depot, OSH, all don't have the blank. - JimM68ExplorerMine, those lock cylinders are all different...
I think Monaco just liked locks. - Big_KatunaExplorer IIGas cap door and water is easy. They are what's called cam locks and they are cheap. Take them off and most lock smiths can rekey them or replace them. They are less than $10 each.
One less key.
Trimark door lock is pricey. I only use one lock, don't carry the dead bolt key but have a full set hidden outside.
One less key.
Why carry the ignition key when your not driving?
One less key. - BillinwoodlandExplorerDrives me nuts with my Monarch. At least all the basement doors are keyed the same.
Bill - 10forty2ExplorerYep...got all those keys too. Only solution is to replace all the locks. I posted the same frustration a while back and the only answers I got was that most MH manufacturers have several different parts suppliers to build one MH and as such they buy access doors from different suppliers with different locks. The interesting/scary thing is that I'll be willing to bet that my keys would fit and work in some of your locks.....
- Dutch_12078Explorer IIIFind a good locksmith and see if he can rekey enough locks to use the same profile key.
38,769 PostsLatest Activity: Mar 31, 2026
