- Fyr_guyExplorer
Jim Bakker wrote:
bricot wrote:
Had a bolt shear off of one of our big slides last weekend when trying to pull it in.
What happened to indicate a problem? Were you able to retract the slide or did it get stuck in an extended position? Inquiring minds want to know all the details!
On mine, I noticed the living room was not coming in evenly, went outside to take a look under the slide, noticed the broken pin on the ground. I actually was able to turn the long metal bar by hand to return the slide to the out position. I then came inside to do the research on Power Gears site and it explained how to "Unlock" and unplug the motor from the bar in order to replace the shear pin. Hope this helps. - Fyr_guyExplorer
FreshAir wrote:
Fyr guy wrote:
I had the same issue with the slide. I'll call the bolts shear pins as I believe they were designed to break before any further damage can occur. I was at home when this happened and I fixed it temporarily as Bricot did and then ordered the parts through Power Gear. I also ordered extras just in case.
I think that over time they just give up after years of not quite level operation putting extra strain on the bar. I was surprised that it was a pretty easy fix, even for me.
Fyr or Bricot, when one calls Power Gear for a shear bolt how do you refference or describe the bolt you need? I think a spare might be the way to go.
Pat
While doing thr research on PG site I actually found the part # in the schematics and ordered it that way, sorry I don't have the number. - Jim_BakkerExplorer
What happened to indicate a problem? Were you able to retract the slide or did it get stuck in an extended position? Inquiring minds want to know all the details! - FreshAirExplorer
Pat - Fyr_guyExplorerI had the same issue with the slide. I'll call the bolts shear pins as I believe they were designed to break before any further damage can occur. I was at home when this happened and I fixed it temporarily as Bricot did and then ordered the parts through Power Gear. I also ordered extras just in case.
I think that over time they just give up after years of not quite level operation putting extra strain on the bar. I was surprised that it was a pretty easy fix, even for me. - FreshAirExplorer
bricot wrote:
Got the pre-recall letter in the mail.
Had a bolt shear off of one of our big slides last weekend when trying to pull it in. Fortunately I had tools and found an autoparts store that had some grade 8 bolts that fit.
May see how much the new drive bar is since the holes were a little mis-shaped after that.
I suppose I should try and think of a parts list and get them now before their Chapter 11 status gets worse... Dang it, I really liked this coach and was looking forward to a new one...if hey ever incorporated bunks...
Any thoughts as to what caused it to shear other than just normal fatigue?
Pat - bricotExplorerGot the pre-recall letter in the mail.
I suppose I should try and think of a parts list and get them now before their Chapter 11 status gets worse... Dang it, I really liked this coach and was looking forward to a new one...if hey ever incorporated bunks... - hammer01ExplorerI am sure that most of you know that you can call fleetwood owner services and ask for the parts department. if you give them your serial number or F.I.N.(fleetwood identification number) they can tell you anything about your M/H. i called the other day about a torn window shade and they told me what color and style shade i had and i purchased one from them. it came in and i installed it, looks perfect. owner services phone number is 800-322-8216.
- hammer01ExplorerI have a 2004 pace arrow, we purchased it new in 2004 and so far we have put 28,000 miles on it. we tow a 2008 full size a gmc truck. i think that it would be nice to have an active pace arrow group. from reading the various post, i have a good idea why my mh rides like a tank. contact me anytime. Jeff
- rolnhomeExplorerAny one going to the Fleetwood rally june 27th in Gillette,Wy?
38,768 PostsLatest Activity: Jan 26, 2021
