- rgatijnet1Explorer III
How Dun wrote:
Check the circuit breaker on your Inverter itself. This will be in your basement on the inverter cabinet and sometimes one or both will trip
I've been looking for it but so far can't find it. Do you know where it's located??
Do you mean you can't find the inverter or you can't find the circuit breakers on the inverter?
Usually the inverter is located reasonably close to the house batteries and may be in a basement compartment next to the batteries. The circuit breakers are mounted on the side or front of the inverter cabinet. Some are push buttons and some are lever type breakers. - How_DunExplorerCheck the circuit breaker on your Inverter itself. This will be in your basement on the inverter cabinet and sometimes one or both will trip
I've been looking for it but so far can't find it. Do you know where it's located?? - rgatijnet1Explorer IIICheck the circuit breaker on your Inverter itself. This will be in your basement on the inverter cabinet and sometimes one or both will trip.
- Dutch_12078Explorer IIITry resetting the breaker at the power stanchion. One leg of the 50 amp service may have tripped, which should take out both legs on the breaker, but sometimes doesn't on a worn or damaged one.
38,763 PostsLatest Activity: Jul 22, 2018
