JRscooby
Jan 25, 2020Explorer II
jackie wrote:JRscooby wrote:
What does the gauge say?
Power to buzzer should be switched by main switch
The gage reads what it always has, between 60 and 80.
Everything works great, brakes, air ba suspension, but the darned alarm will not turn of, whether the key is on or off.
If I knew the wire that fed it electricity, I would disconnect it. Right now, I can’t even find the alarm, and I have the dash taken apart.
Sounds to me you have more than 1 issue.
First, if your system maxes out at 80 and has for a while you have a bad compressor or more likely leaks. If you have been driving like that you should be shamed.
If the buzzer is on with the "ignition" switch off, you have power getting to it from someplace it shouldn't.
