dougrainer
Jan 25, 2020Nomad
Sorry, Air systems should be OVER 110 PSI. The cut off for a Air System alarm is the 70 to 80 PSI. So, the system is accurate. Your problem is inadequate air pressure in the tanks. OR the air PSI gauges are wrong and your air is over the 110. Regardless, if you show 80, that is your problem. I have never heard of a Air alarm going OFF when the key is OFF. Makes no sense as when parked and you exhaust the air system, the alarm would go off if wired for HOT all the time. Doug
