dougrainer
Jan 25, 2020Nomad
jackie wrote:
The gage in the 2000 Diplomat has no numbers on it, just lines. There is a line where the alarm has always cut of at. The gage reads well past that, well over 3/4 of the way around, so I doubt that low pressure is the issue.
Some of you are not listening . The alarm is going of with the key off, parked. The only way To stop it is to disconnect the battery. When you reconnect the battery, it just starts going off again.
Some of us ARE listening. IF NO NUMBERS, how do you state that it was 60 to 80 PSI????????????????????:) AND, You have other problems if the alarm goes OFF with Key off. You have an Ignition side that is HOT with the Key off. So, you have 2 problems. The air alarm is the low Pressure switch system has a fault most likely a bad air sensor. Then fix the Key OFF problem. Doug
