David0725's avatar
David0725
Explorer II
Sep 27, 2022
Low power?
I have a 2003 DS 50amp It is currently plugged in to my 30amp server at my house. Im using 2×25ft 50amp cords.At first it's show 111volt turn on the A/c it drops 108 or so. What could be causing this? But with I run the generator it's fine 115 120. Thank you in advance.
  • I suspect DS is Dutch Star (Newmar). “Server” may be “Service”. Is it possible to move closer? You might want to consider upgrading the service to 50 amps.
    As above the length of cords will reduce the voltage. Generator is properly sized for the MH providing 50 amps, and is really really close by.
  • if it drops below 108v i'd disconnect before damage is done. but what's a 'DS' and what is a 30-amp "server"? do you mean a 30-amp outlet at a campsite? but the first response is likely correct...voltage drop through the cords. did you measure the voltage at the post?
