hotjag1's avatar
hotjag1
Explorer II
Oct 19, 2015
Low water light came on, but...
As I was going up a long grade the low water light came on but the temp gauge showed perfectly normal. Got to the top of the grade and pulled over to check everything. No coolant is leaking anywhere that I could see and the sight glass in the overflow tank was full(sight glass was completely green).
Tried shutting engine down and restarting, but that didn't change anything. Since the engine was running at 190 degrees like always, I drove about 20 miles to an RV park. I will check the coolant level in the morning when the engine is cold and see if the overflow tank is completely full.
In the meantime, has this happened to any of you? What possible reasons could cause the light to come on and still have the engine running cool?
I unplugged the sensor connector on the overflow tank and that didn't change anything, so I plugged it back in.
Thanks for any help on this.
