Deano56
Aug 29, 2015Explorer II
LP Fill Fail
I went to Menards tonight after we filled the tank with gas, so that I could get a fill on LP. The girl screwed the nozzle on the fill port and pulled the trigger, gas shot out the vent, so she tried ...
Old-Biscuit wrote:Deano56 wrote:Old-Biscuit wrote:looks like the piece on the right of the fill port, not sure about the gasket, I would assume it was there but who knows. I'll check tomorrow
I'm not sure what you mean by 'vent' :H
Did she close the 'service valve'?
Did she hook up propane hose/nozzle to the 'fill' connection?
Was the gasket there?
To the right of the fill port in picture is the 'bleeder valve' .
It should be Cracked OPEN when filling.....vapor comes out and then when it starts spitting liquid you STOP filling and close bleeder valve. Bleeder valve is set at 80% liquid level.
Sound like bleeder is still open or has failed.
Tank needs to be empty to replace.
