Chum_lee
Oct 04, 2018Explorer
spotrot wrote:
Thank you all for your advice and recommendations.
RE: shuddering. Mine is not shuddering, my friends similar trans was and the additive helped stop it. Apparently the friction material in lockup converters can need help as it ages.
RE: recommended fluid change. My Ford manual says change at 60k (30k for ones with external filter) so I'll soon remove the pan, change the filter and install fresh Mercon SP.
I was simply asking if anyone had experience with Lubegard Platinum
RE: #1 RE: All the more reason to avoid experiencing/using Lubegard
RE: #2 RE If you do that: All the more reason to expect that your transmission will continue to work properly for as long as possible!
Chum lee
38,777 PostsLatest Activity: May 24, 2026
