charred51's avatar
charred51
M1512 Trace Inverter & Charger
I have a Airstream Diesel Cutter with a M1512 Inverter Charger. Have power to house battery from outside source but can't get the power from the batteries to the inside of coach. AC comes in but DC doesn't. Had plugged in to RV park's 50 amp. No problem until then. Thank you.
  • So what you are saying is your converter is not working? Trying to understand.
  • 1512 inverter charger, if it's working and charging the batteries
    And you have no 12v power in the RV , lights , water pump etc
    Battery disconnect is off ? Or bad,
    Main fuse at dc distribution fuse center is out ?
    What do you mean power to batteries from outside source?
  • Check to insure you are getting 12 volts to the inverter. You could have a blown fuse.
    Has any battery work been done?
    Have you checked and reset small circuit breaker on the inverter? What about the inverter breakers?
