Karsty's avatar
Karsty
MACERATOR PUMP NOT WORKING ... AGAIN!!!!
VEHICLE: 2012 Winnebago ERA with a macerator pump to drain the waste water tanks.
I had a problem a year or so ago where the pump was apparently blocked with waste material and keep blowing a fuse every time I tired to use it. Took to dealer ... fixed to the tune of $150.00.
Since that time I no longer use the black water tank ... only the gray tank. Had no problem earlier this year emptying it ... worked fine. Today nothing. Pump does not turn on. Fuse is fine.
I'm guessing maybe the waste pump switch???
QUESTION: Has anyone converted their macerator system to a gravity system on a Class B? In my view the macerator pump is a nuisance and just something else to go wrong ... too many times to suit me.
Thanks for any thoughts.
