Had a 2002 Journey for 8 years. The 'salesman' switch is on the dash to the right of the gauge cluster.... think it was second from top. That will disconnect the house batteries. The '02 did not come with a chassis battery disconnect but you can add one.
Even with the dash switch shut off, there are parasitic loads on that coach that will discharge your chassis batteries if you leave it for more than about 5 - 7 days. So plan to use some sort of battery maintainer to keep the chassis batteries charged if you plan to have it sit. I installed TrikLCharge which keeps the chassis batteries charge as long as you are connected to shore power.
