MountainAir05
Nov 10, 2021Explorer II
rabnud wrote:MountainAir05 wrote:
Think you have a control failure. A short and you would not have anything electrical working. Try these links. There were several recall on this. Its a old system and no repair that I have found, just remove and go without or put in another system. Its was a monitoring system that did not last long. Too long ago to remember all the issues. Seems like you could turn it all off and take the power off it. The first link might have that info.
Eplex
#2
thanks for the information;;Iam leaning more towards a grounding problem once i find out what the #293 module is It may help me some also
also the on board security system started going on all by itself
when this first happened the unit was running and it locked the door while they were outside the coach while it was running ;;luckly it also resets itself
Sounds like you got some water inside a sensor or relays. If the relays are not seal which sound like they are not, then you can take apart and dried out. Hopefully it will dry out fast. Leave the battery disconnect for 30 + minutes if you do a reset again.
