rabnud
Nov 10, 2021Explorer
enblethen wrote:
From another RV forum:
"Final update: FIXED IT!!!!!!!!! Received The actual eplex wiring diagram from Newmar. The E-plex fuses are located in the back of the shore power cord compartment.* There are two inline fuses and a 24v step up converter installed. Newmar used the step up converter only the first year and realized wasn’t required. I bypassed and removed the converter. Two fuses were good, but there was a 12v panel the red wire connected to with a 5amp fuse.. it was blown. Power returned to the system."
Might look for fuses on your rig.
will take a look although My eplex works and has power to it just sometimes it goes into the missing modules display and then you cant control anything ;; also have to find out where the phantom power to the dash comes from when turning on key with chassis batterys disconnected and why turning on the head lites shuts it off
and why the water pump sticks on and starts the generator this is a perplexing mess so far
