rabnud
Nov 13, 2021Explorer
dougrainer wrote:rabnud wrote:enblethen wrote:
System could be back feeding to the dash via the charge relay system.
Possible from bad ground. Check connections in battery compartment.
another dumb question I open the electrical compartment and see two black solenoids one I assume is for boost and one is for??
I check with test lite and power to both side of both solenoids with chassis battery's on or off
One should be the COACH battery disconnect. Test the solenoids with Coach disconnect OFF and NO 120 Power to the RV. Doug
thanks will do that for sure
