rabnud's avatar
rabnud
MAJOR short on a 2006 newmar essex
regarding a 2006 essex any one know what the #293 module is for;; its in the main control system for heat /ac/ gen start/ inverter/ etc etc says module #293 failed
also have a major electrical issue where at the same time the water pump stays on the generator starts all by itself ,the lights flash and the and the main control panel says missing a module #293)
also if u turn the ignition key on the dash lights for the engine controls etc illuminate even though the chassis battery is turned off!! (wont start or turn over though) If u turn the headlight switch on and off everything goes off /back to normal also the brake control flashes and goes off when the headlite switch is pulled on/off as the other stuff
any and all ideas and questions welcome
  • enblethen wrote:
    System could be back feeding to the dash via the charge relay system.
    Possible from bad ground. Check connections in battery compartment.
    I already did that but going saturday to recheck things like that
    the more i think about it it really has to be a grounding issue because of things like pulling the headlite switch on/off shuts off the phantom power feeding the dash etc
    what you think ??
    appreciate your help here in this matter
    another dumb question I open the electrical compartment and see two black solenoids one I assume is for boost and one is for??
    I check with test lite and power to both side of both solenoids with chassis battery's on or off
    One should be the COACH battery disconnect. Test the solenoids with Coach disconnect OFF and NO 120 Power to the RV. Doug
    thanks will do that for sure
