memtb
Aug 14, 2019Explorer
Just yesterday, I installed our new Hellwig Sway Bars on our Ford E 450 (2006) chassis class c. It was easier than I expected, and going very well.....untill, when removing the last (very last) bolt. It was the last bolt remaining in the rear bar bushing mount and sheared-off the bolt when trying to remove it. After approximately 2 hours attempting to drill it out, and remove with an easy-out (not “easy”....failed), I drilled it out, and tapped larger to a 7/16 SAE bolt.
Going for a little test-run today....to see “if” it’s “road manners” are improved! Stiff and sore fingers crossed! memtb
38,782 PostsLatest Activity: Nov 09, 2020
