nomad2013's avatar
nomad2013
upgrading steering and suspension recommendations
2007 Fleetwood 24ft motorhome. Looking for the best way to improve steering and suspension. Best type facility to do the job and what might be the estimated cost.
Thank you.
  • Great responses from all of you. I will taking this information to a commercial truck repair shop for installation. Thanks again for all your input!
    • If the rig's rear bumper sags more than four or five inches between loaded, not loaded add more leaves to rear springs. If the complaint is excessive leaning around curves a rear sway bar will help. a bigger front sway bar will further improve stability
    • As noted the best-rated shock absorbers are a must:I like KONI but maybe there isn't a number available
    • Maybe after these upgrades you won't need the steering fixes
  • I just posted the topic. I thought it would go into a general topic agenda.
  • My last 28’ MH on a Ford F450 chassis had these upgrades:
    Bilstein 4500 series shocks
    Bilstein steering damper
    Firestone front airbags in the front springs
    Steering box adjustment for tighter response
    Proper front wheel alignment for the weight of the unit
    Tireman brass extenders on each wheel to easily keep tire pressure at the proper psi
    With all of this, the 28’ MH handled very well.
    The next step would have been a Roadmaster rear sway bar, but I ended up trading the unit in for my current fifth wheel.
