- yankee_camperExplorer
bsinmich wrote:
Keep in mind that white will be cooler than silver. If you don't believe that try touching 2 different cars in a parking lot
Prior to my painting the roof white my gut instinct was that a silver(aluminum) roof would reflect more heat than anything i.e. mirror effect? I was wrong although I still don't get it:h - bsinmichExplorerKeep in mind that white will be cooler than silver. If you don't believe that try touching 2 different cars in a parking lot
- PSWExplorerGo to Walmart and buy a large green tarp with silver reflector on one side. I think (?) mine is 14x20 feet and it costs $20something. Put it across the top and see what happens. The AC, vents, etc should hold it a few inches of the roof. I would be sure not to obstruct the venting of the AC.
We just got backed from a multiweek trip and the sun was intense. I used one of these things to shade and the silver side did a great job a reflecting direct heat.
The truth is, in my experience, if it is REALLY hot like it gets in the SW and W, an RV is going to be hotter than I want it to be regardless. - yankee_camperExplorer
timmac wrote:
yankee camper wrote:
I have a 1990 Coachmen 25 ft. 5th wheel with an aluminum roof. Being anal I painted the roof with white Dicor Elastomeric paint. Did a great job at controlling indoor temps, I would say it knocked it down a good 5-10 degrees... but the stuff lifted and peeled like a sunburn on an Irishman in the desert w/in a year. To add insult to injury when it flakes off during a bath or rain storm it sticks to the siding and won't come off unless you sandblast it!!! If anyone out there has a suggestion I'm all ears.
You have to primer the roof if you want it to stick to bare metal, don't have to on other roofs just bare metal.
Would have been some good info to print in the instructions on the can:h
Nope nowhere on the can does it suggest priming the roof, basically states the 1st coat acts as a primer. I'm not a total idiot (maybe just 1/2) but being new to this application I followed the directions on the product to a "T" with less than stellar results.
Just ask the people at the store where you bought it they should be able to help, I am sure somewhere on the product it says to primer bare metal and they might even sell the primer that works best. - timmacExplorer
Just ask the people at the store where you bought it they should be able to help, I am sure somewhere on the product it says to primer bare metal and they might even sell the primer that works best. - yankee_camperExplorer
Would have been some good info to print in the instructions on the can:h - yankee_camperExplorer**double post deleted
- mgirardoExplorer
Bordercollie wrote:
I wonder how comfortable full timers are in typical Class C's in really hot weather despite all of the things that can be done to help survive the heat. Maybe they find a library, senior citizen's center or movie theatre.to get through the hottest times of the day.
I don't know about full timers, but we camp seasonally for 4 months. Right now we are in the middle of a heat wave. The curb side faces due west and we have little shade. It's been in the mid-90s with high humidity for a few days and will continue for 4 or 5 more days. Our 13.5k A/C cools the camper fine.
Yesterday the outside temp was 96 while the inside temp was 75. The A/C runs a lot, but it keeps the camper cool. When it gets this hot, we usually close off the back half of the camper (we have a pocket door between the front half and the back bedrooms) and open two of the vents on the A/C unit so it pours most of the cold air into the front half. That allows the A/C to cycle more often. It still runs a lot, but not constantly. The back half of the camper stays cool enough.
We also have a thermal curtain between the cab and the house and that really helps keep the heat in the cab. It is surprising how much warmer the cab is when the curtain is kept closed.
-Michael - timmacExplorer
38,782 PostsLatest Activity: Sep 10, 2026
