DutchmenSport wrote:
We never use any cleaners on the toilet. Just water and a toilet brush. Very rarely we'll wipe it down with a bit of bleach, usually at the end of the camping season, but not enough to flush down the drain! Dishwashing soap is probably the best to use if you just want to clean it. (Dawn is great!)  But really, brush and water is all you need. We brush after every use and wipe any liquid spills immediately. Whoever uses it, cleans it immediately! That's our rule. Nothing worse than lifting the lid and seeing a horrid mess. Keep water in the bowl. It makes a seal from the tank below and keeps smells from happening.
By the way, dishwashing water is good for your black tank. It will help clean it. So FREELY pour your dishwashing water down the toilet. Do this, and you'll never need chemicals in the black tank. And the dishwashing water will clean the bowl too.
Ditto and:
Before you go
Before you go spray EVERYONE in the RV will thank you.
