wa8yxm wrote:
If it were a straight Microwave I would say no
But since it is a convection/microwave the answer is not as clear.
Remove it to the picnic table outside the RV
now inspect the thing,, Look for a fuse or reset button. IF you find none (I'll be surprised if you do) then...
Remove the outer cover CAREFUL there may be sharp edges the use of gloves (leather) when handling metal parts is highly recommended.
(Friend of mine read that warnign too late)
Again look for a fuse or breaker.
I have seen two of them where the only problem was a wore out fuse.. Fuses do wear out and blow for no good reason.
I have also seen burnt wires and blown diodes
And I have only worked on 4 Microwaves. (well 5 if you count the turntable motor in my DOMETIC by Lousy Goods (LG). (Replaced it with a GE part and now it works great).
Do be aware if you open up the microwave that there may be very high voltages present, possibly even after it is turned off and disconnected from the power outlet. A microwave magnetron requires a few thousand volts and a non-trivial current (a substantial fraction of an amp) to operate. These voltage and power levels can easily be deadly.
One not uncommon cause of the fuse in a microwave blowing is a dirty, gummed up, broken, or misaligned door safety switch. It's designed so that if the door is opened and the controls don't function properly, the fuse will be blown and the microwave power supply thus turned off before the door is opened widely enough to let dangerous levels of microwave radiation escape. That's not the only cause, of course, but it is a possible one and it can be not difficult to repair if it's a matter of cleaning accumulated crud out. If the door switch is broken, it should be replaced only with an identical one due to its being a safety interlock device.
In this case, a thermal fuse blowing does sound reasonably likely since the problem happened on convection cooking, not microwave cooking.
