Itasca55's avatar
Itasca55
mice in my onan :) yes I had stowaways
I was working on my generator and got it fired up fuel pump ground wasn't making contact . and was getting some serious smoke . Come to find out there was huge mouse nest right on top generator inside metel shroud. I could just get shroud off enough to vacum out a big mouse nest. I mean acorns insulation and other fine stuff. Now my question how to keep mice out of my onan 4000 J they love it. fresh cab air freshener. screen ??? any ideas be great . taking shroud off is a big pain. also another question on gas line . Mine has hose going from pump to supply line just behind generator box then small metal line going all the way back to gas tank. but metal lines just laying on top of stuff loose resting on big exhaust pipe shields and floppying around up in there.
it looks like it goes back to rubber hose close to the big gas tank .
do I zip tie it up to stuff with plastic protectors :h??? any ideas be great . Thanks
Itasca55
P.s. on mouse nest it was still burning as it hit the vacuum it wasn't a pretty smell vacuum will never be the same :) no mice were harmed it was a vacant nest LOL.
  • Gjac wrote:
    Two years ago when I had to replace a bad coil in my Kohlar Genset I saw the same thing when I removed the shroud which is a pain to remove. It is a wonder how it did not catch on fire. I just removed it again last week to adjust the mag pickup and it was nest free.
    I was thinking on using aluminum screen all around generator to keep mice out . person could secure it with magnets and wire ties . because I dont want to think about all the time is there a nest in it or not :)
    someone else Had to come up with this idea . :)
    Itasca55
  • Gjac's avatar
    Gjac
    Explorer III
  • Whenever I have to do something nasty like that I rent the equipment, even if I have my own. :B
