allbrandauto's avatar
allbrandauto
michelin 235-80-22.5
have a Fleetwood bounder workhorse 8.1 Allison 6 speed trans want to switch tire size from mich. 235-80-22.5 to tire size close with out mich. price will it effect trans. shifting or bring check engine light on for different rpms on trans. going down road
    As long as the tier size is the same you will have no problem. You can actually be off quite a bit before you will have a problem. Just be Shure you have the right load rating. Most good truck tier shops should be able to find tiers that will work.
    Bill
  • Check out FMCA and their Michelin Advantage program. You can buy that tire for a very good price that way.
