rk911's avatar
rk911
Michelin Tire Issue
2016 Itasca Suncruiser 38Q-U1 (F53 26K chassis) with Michelin 255/80R 22.5 XRV tires on both axles. The MH has 11,000+ mostly interstate miles on it. After pulling into our current park a few days ago the parking assistance noticed that the two front axle tires were severely worn on the outer edge with the left front tire being the worst...the steel belts are just about ready to show. This is my first experience with Michelin tires as well as with 22.5-inch tires. Both of our previous MHs had Goodyear tires with which we were very happy and gave us excellent service and miles.
I noticed no excessive handling issues leading up to the discovery. I did have a steering stabilizer (Blue Ox TruCenter) installed just before we left on our current trip (early March). Pressure is set per inflation tables. From what I can see the dualies on the rear axle seem ok.
Several folks in the park who claim they have the necessary experience tell me it is not an alignment issue, not the fault of the steering stabilizer but rather a poor tire. One urged me to get Toyo tires, another suggested BF Goodrich. One of the local tire shops that deal in 22.5 tires suggests going with Michelins. Since I had good service from Goodyear I am leaning towards the G670s but the shop says while they will sell them to me they will not warrant them. A quick search of the forums seems to suggest that the Michelins are a poor tire but there are those who love the Michelins and hate the other brands. Needless to say the options, along with what might have happened had the discovery not been made, are spinning in my head.
I'm looking to replace these tires with a quality tire. Price is not an issue as I don't believe in scrimping on tires but I do believe in value.
Questions:
- looking for thoughtful, reasoned opinions on the replacement tires.
- I'm planning on having the 4-rear tires examined and if OK I'll leave them be. Any reason not to?
- I'm going to have the front-end re-aligned post tire purchase. I'm also having the Blue Ox TruCenter examined to make sure it was installed correctly and is operating properly. Is there any reason to suspect a bad alignment or the TruCenter as the proximate cause of the tire issue?
- We're currently in Phoenix (Mesa) until mid-April and have spoken with Robert's Tires and will be speaking with Danny's Big Rig Resort in the next couple of days. Does anyone have any experience with either shop or have any other dealer recommendations that deal in 22.5-inch tires?
Thanks for reading.
  • Time to have a four wheel thrust angle alignment done on your coach. The front and could be aligned perfectly but if the rear axle is not pointing straight down the road it will cause a lot of weird wear on your tires, and also lower your fuel mileage.
  • your camp ground experts are wrong ,theres something not right here ,you,ve got the best tire made on your rv now. find a big rig shop and have it fixed,
  • rk911, I've run Michelins and Goodyears. Both performed well. Had one GY suffer rivering but all others are good. Since you're experiencing uneven wear on both sides, that indicates an alignment issue. While bad shocks will wear your tires too, usually that will result in bump on the tires that you can feel. Before you make the decision on tires, I'd invest in a alignment check. Fix the problem before you give up on any tire mfg. I'm not knocking Roberts Tire, but use caution when purchasing from them. Especially the Power Rd. shop. A lot of those tires sit in the hot Arizona sun for a long time. Insist on fresh tires.
    I'd also recommend Spectrac Alignment shop, 405 E Baseline Rd, Gilbert, AZ 85233
    Phone: (480) 545-5533. I've used them twice and found them to be reasonable and very knowledgeable. They are on Baseline just off Mesa Drive near La Mesa RV. Call them and explain your situation, or stop by with some pictures and get their opinion....BOL....Dennis
  • Heisenberg wrote:
    Those Michelins are nearly bulletproof. Mine have always aged out ... other than picking up a nail or two and I never saw any uneven wear.
    There is a rat in the woodpile.
    Yep, Somptin Wong.. never a problem with Michelins
    both tires worn on the outside edge? too much tow in.
  • Those Michelins are nearly bulletproof. Mine have always aged out ... other than picking up a nail or two and I never saw any uneven wear.
  • If any Goodyear Tire outlet told me that they would sell me the tires but refuse to warrant them I would be on the phone to Goodyear real quick. Also any other tire dealer in the same circumstances would get the same response! Why are these people selling tires that they obviously consider inferior and not worthy of warranty by them. In most cases they would be compensated by the manufacturer unless that manufacturer is willing to admit that they were selling tires that were expected to fail prematurely.
  • rk911 wrote:
    2016 Itasca Suncruiser 38Q-U1 with Michelin 255/80R 22.5 XRV tires on both axles. The MH has 11,000+ mostly interstate miles on it. After pulling into our current park a few days ago the parking assistance noticed that the two front axle tires were severely worn on the outer edge Both of our previous MHs had Goodyear tires with which we were very happy and gave us excellent service and miles.
    I. Since I had good service from Goodyear I am leaning towards the G670s but the shop says while they will sell them to me they will not warrant them.
    I have had great service with no issues with the GY G670 tires. I am not sure I understand the dealers position of no warranty for the GY tires. The warranty is provided by the Good Year mfg. not the dealer. The dealer's job is to send a problem tire back to the Good Year tire Co. and then install a new GY G670, balanced and new metal stems at no cost to you!! I would not buy the tires from dealer but rather find another dealer to buy the tires from!!!! "I'll sell you a tire but will not warranty the tire" NOT!!!!! Stay away from this dealer:) Call Good Year Mfg. customer service and ask for a recommendation of a local dealer in your area. I have bought the GY G670 tires from Big O Tires in Surprise, Ariz.
    Thanks for reading.
