Bobbo
Oct 19, 2015Explorer III
goreds2 wrote:
I reset all the breakers, the 30 amp does not want to stay in the on position (all the way to top?).
Unless you turned it all the way off before trying to turn it back on, it won't stay up.
If you DID turn it all the way off first, then I agree that you have a short somewhere. The suggestion of turning off all of the breakers and turning them back on one at a time is a good one. It will identify the circuit with the problem. That will narrow down the possibilities a lot.
I disagree with the ATS as a suspect. It is before the breaker box. If it was the problem, the breaker at the pedestal would be the one tripping, not the breaker in the RV.
